Channel Editor Program(Beta version) Released
Post by xbmc » Fri Jun 27, 2014 1:46 pm
Channel Editor
http://www.xbmc4stb.net/XBMC/program/ChannelEdit.exe
http://www.xbmc4stb.net/XBMC/program/7z920.exe
How to use Smart Hybrid XBMC Editer(Beta V 1.0)
1. Editor's Functions
Edit channel name,
Set Parental Lock flag.
Sort channels by Number. Provider Name, Channel Name, Satellite name, FTA->Scrambled
Edit Favorite List
Move channel.
2. Install “7z920.exe” program on your PC and remember where this program installed.
Normally 7 zip program will be installed on below folder.
C:\Program Files\\7-Zip
C:\Program Files (x86)\7-Zip : 64bit
3. Prepare backup file
After doing backup, you will have tvdata.tar.gz file on your USB stick.
4. Execute “ChannelEdit.exe” program.
5. Set 7z program path on Channel Editor
6. Select tvdata.tar.gz from USB Stick
7. After loading channels, channel will melt on temp working folder on your PC.
8. Edit DB what you want
9. Save your DB to tvdata.tar.gz file to your folder.
10. In channel Search page, press blue button to restore after insert USB Stick with tvdata.tar.gz.
Enjoy with your channel DB.
rmafortunato
Re: Channel Editor Program(Beta version) Released
Post by rmafortunato » Fri Jun 27, 2014 9:45 pm
Hello thanks for the first release :)
you guys are thinking to do a OS X version?
Post by xbmc » Mon Jun 30, 2014 8:45 pm
sorry, unfortunately, we don't have plan to support X-OS
Return to “Announcement”
