New Firmware release : 2014.08.20
18 Aug 2014, 09:17
[ADDON Feature]
- Enabled Autoupdate for Addons
- Added dependency external lib with some addons.
- changed new addons.zip. (Navi-x3.8.2... etc)
[FrontEnd Feature]
- Fix numeric channel change error in case no recording
- Support Web EPG url saving feature.
- Fixed audio output setting and sync xbmc mute and android mute.
- Fixed Unicable issue.
[PVR Feature]
- Fixed many PVR issues.
- Update same time recording up to three channels in same Transponder
- Fixed Recordings on timers
blocked installation that can't support as below Music addons( need to more debugging..)
- plugin.audio.dr.dk.netradio
- plugin.audio.abcradionational
- plugin.audio.sky.fm
- plugin.audio.soundcloud
- plugin.audio.jazzradio.com
- plugin.audio.icecast
http://www.xbmc4stb.net/Firmware/U4/201 ... DDONS-IPTV
http://www.xbmc4stb.net/Firmware/U4/201 ... ormal-IPTV
