[Change log]
-Support multi language keyboard in android keyboard
-Fixed DTSpassthrogh in xbmc mode
-For LED(EU models) make more dark for LED brightness
-Added Search option as FTA/CAS
-Added find function in IPTV List
-Added backup function on USB Stick for IPTV List and Add new IPTV link.
- Speed up Channel up/down in IPTV mode.
- Channel select with numeric and display channel number to front display in IPTV Channel.
- Added mgcamd/avatarcamd protocol on OSCAM
- Added OScam Restart Feature on Menu.
-Applied new addons. (include "playlistLoader")
http://www.xbmc4stb.net/Firmware/U4/201 ... te_all.zip : clean all user data.
http://www.xbmc4stb.net/Firmware/U4/201 ... ential.zip : Keep all user data
After downloading file, please use after renaming update.zip.
New Firmware release : 2014.11.06
http://www.xbmc4stb.net/viewtopic.php?f=10&t=5aissaok wrote:how to update update_essential
thanks
Thank you for the update. I did not know there would be so much work involved to get to the release stage.
