New Firmware release : 2014.12.19
Post by xbmc » Sat Dec 20, 2014 9:35 pm
[Change log]
Added Android Task Bar : Press Home button to use Android Task Bar.
Fixed channel Recall function
Changed broken Default Weather Addon : Yahoo
Added Default Android Apps.
1.Quick Pic : To see photo/picture files
2.JetAudio Basic : To listen MP3 files
3.MX player : video files.
4.AirDroid : To access U4 box from PC and send file to U4 box
5. Weather & Clock Widget : For Weather
6. F-Droid for Market
http://www.xbmc4stb.net/Firmware/U4/20141219/update.zip : clean all user data.
Due to default Android App upgrading, We don't release unclean version so please backup your data before upgrading SW.
wassim33
Re: New Firmware release : 2014.12.19
Post by wassim33 » Sun Dec 21, 2014 9:32 am
thx for u r support and hope this soft will clear all problems and i want to ask again where i can find activation code for tu-iptv thx again :D
Post by xbmc » Mon Dec 22, 2014 3:38 pm
check below link.
http://www.livetv.tn/
mija1260
Post by mija1260 » Mon Dec 22, 2014 5:53 pm
Does this firmware update solve problem with passthrough digital signal (DD, DTS) via HDMI (not only via coaxial), both from satellit and when playing MKV files from XBMC?
AbouImran
Post by AbouImran » Tue Dec 23, 2014 2:21 am
hello
any news for root?
thx for support
marinaish
Post by marinaish » Tue Dec 23, 2014 11:38 am
where is the internet tv menu?
Post by xbmc » Tue Dec 23, 2014 12:40 pm
marinaish wrote:where is the internet tv menu?
==> Main XBMC menu : Internet TV
mija1260
Post by mija1260 » Tue Dec 23, 2014 3:08 pm
[Change log]
If I press Home button, I go to Android screen, not display Android Task Bar
I dont see new default Android Apps # 1. to 4., only F-Droid, as in previous firmware. And how I can add Widget to Android screen?
AbouImran
Post by AbouImran » Wed Dec 24, 2014 3:25 am
hello when can i buy me-iptv?
marinaish
Post by marinaish » Wed Dec 24, 2014 12:17 pm
Internet tv does not exist in the xbmc main menu
Return to “Announcement”
