Homeworx 5000 Firmware
U4 Quad Hybrid
18 Feb 2016, 07:43
HWA 5000 model :Support Tuner modules
USA/Canada/Korea combo(ATSC+S2), ATSC.
-------------- 2016413 --------------
Hi3798MV100 SDK 58 version : Keep DB version.
Normal version : https://drive.google.com/open?id=0B_dRT ... k10ZjdzN1E
Link : Quad/Firmware/HWA5000/20160413/Normal/update.zip
Hi3798MV100 SDK 58 version : All reset version.
Full version : https://drive.google.com/open?id=0B_dRT ... UxoZ2pLcXM
Link : Quad/Firmware/HWA5000/20160413/Full/update.zip
1. Added Fav/Group list.
- Press "FAV" button on RCU to see FAV/Group list.
2. Added Channel detail information menu .
3. Added IPTV Menu.
60,61,62,63 SKD Full Version :
https://drive.google.com/open?id=0B_dRT ... lk1QmlZNk0
1. Updated Dolby features
2. Updated IPTV Codecs.
3. Updated stability of Android part.
-------------- 20151218 --------------
Link : https://drive.google.com/open?id=0BxT86 ... W9TaldDeFU
Link : Quad/Firmware/HWA5000/20151218/update.zip
1. Support 1080P resolution UI
2. Support Screen Capture function
3. Support Sync after modifying channels via TVHeadEnd Web Interface.
4. Fixed Bluetooth on/off bug when box power off/on STB.
5. Modified Time Shift function.
-Store Time shift file.
- Fixed some bugs.
6. Support NAS Via MediaCenter App
-------------- 20151127 --------------
Link : Quad/Firmware/HWA5000/20151127/update.zip
1. Added Find by name Feature on Channel list.
2. Added Find by CH No. Feature on Channel list.
3. Added Fav App list : Netflix, Kodi(15.2) Youtube(for Android TV), Facebook, Skype
-------------- 20151118/20 --------------
Link : Quad/Firmware/HWA5000/20151120/update.zip
1. Change Boot up sequence.
2. Support TV Recording & Content Watching(like Media, Android App, Recored PVR) as same time
3. Support Unicalbe for Sat Tuner.
4. Support DiSEqC 1.2/USAL for Sat Tuner.
5. Add Record button on channel list
-------------- 20151112 --------------
Link : Quad/Firmware/HWA5000/20151116/update.zip
1. Support Power button(Windows Key) on USB Keyboard
2. Support Vol button(Left/Right key) on USB Keyboard
3. Add Dolby TRUE HD codec
4. Added new SW KeyPad for some menus.
5. Fix MP3 codec issue after watching TV.
6. Fixed Sleep timer bug.
-------------- 20151026 --------------
1. Release "HiTVRemte App" in Google market
https://play.google.com/store/apps/deta ... HiTVRemote
2. Revised stablity of EPG.
3. Added Recording Info menu on Popup menu.
4. Added Exception for PVR recording when user go to Specific menu.
5. SAT/TP edit menu on DVB-S part.
-------------- 20151016 --------------
1. Revised stability of PVR/Remote PVR
1) EPG recordings
2) Timer recordings
2. Revised stability of Timer
3. Support Standby/Power save mode
1)Default : Standby Mode
Short power button : Goto Standby
Long(over 4 sec) Power button : Goto Power Save mode
2)Option : Power Save Mode
Short power button : Goto Power Save mode
4. Released Android Mobile App for HWA5000 model - HiTVRemote.apk
1) Support Remote App
2) Support Remote TV guide
5. Support Multi String(English/French/Korean) on help bar.
6. Fixed other small bugs.
-------------- 20150909 --------------
1. Support DVB-T2 tuner module and T/T2/C scanning menu.
2. Support S2/T2-C combo tuner module.
3. Suppport Below tuner module automatically
- ATSC tuner module
- S2 tuner module
- S2/ATSC Combo tuner module
- S2/T2-C Combo tuner module
- S2/S2 twin tuner module
4. Improve DVB-S2 scanning UI.
5. Support Android mobile RCU based Touch interface.
-- Download "Toppy for STB" App on Google market in you Android Mobile.
-- Use it on same WIFI interface.
6. Support Blind scanning for DVB-S2 tuner.
7. Improve DVB-S/T search menu options.
-------------- 20150821 --------------
1. Fixed SW Dolby/DTS Audio issue.
2. Added Backup Channel DB function on eOn Launcer
3. Added Restore Channel DB function on eOn Launcer
4. Added Factory Reset function on eOn Launcer
5. Add information bar transparency control
6. Fixed PVR bugs(EPG Recording)
7. Fixed Fastscanning bug.
8. Added Tuner Lock and Scrambled status bar.
10. changed upgrade menu on eOn Launcer
11. changed Default OSD screen size.(100% ==> 80% default)
12. Added Test version of small update file
1) upzate.zip : full version(include all Android part) of zip file.
2) update_small.zip : partial version of zip file.
To upgrade, you need to rename : update_small.zip ==> update.zip
-------------- 20150814 --------------
1. Auto detect tuner modules.
2. Support S2/ATSC combo tuner module.
3. Support S2/S2 twin tuner module.
4. Added Network/Favorite File Manager
5. Delete Mini EPG
6. Support Latin IME Virtual Keyboard.
7. Added SW dolby App(HF playerPlugin_test) for test SW.
==> Official Dolby will support on Official HW.
==> To active Dolby/DTS, Please connect WIFI or Ethernet on internet.
And execute HF playerPlugin_test App in All App menu.
8. Changed default KODI App version(14.0 ==> 15.0)
9. Support Lock/Unlock function on channel list.
10. Revised PVR/ TMS(Time-shift)operation
11. Active Reset CH DB function.
%%% Fixed small bugs
-- CH Favorite mode
