New Firmware 22 July 2016
U4 Quad Hybrid
Post by xbmc » Fri Jul 22, 2016 6:41 pm
Dear customers.
We are apologize that we couldn't release new SW over long term.
We had a project except this SW over few months. so our team couldn't support this forum well.
We hope that we can support better than before and also come with new product.
Here I leave U4 Quad latest SW.
This is full version with latest SDK.
https://drive.google.com/open?id=0B-Fkg ... XlGcXRSbTg
We only released full version SW to avoid DB conflict.
After checking your SW version, you can upgrade SW on 2 ways.
1.check Baseband version (058 or 063)
last strings are version number.
if you have 063, you must download latest SW from above link and upgrade SW by USB.
if you have 058, then you can upgrade latest SW by Network upgrade function.
mainly updated list.
1. System stability(less rebooting issue)
2. Support normal Android Launchers.
==> To go EonTV app, you can use TV/Radio button on RCU.
Other launchers.
UgoosLauncher : http://smartstb.net/Quad/Firmware/U4Qua ... er_1.3.apk
Minix Launcher : http://smartstb.net/Quad/Firmware/U4Qua ... _METRO.apk
you can install your favorite Launcher to box and use your Launcher and Eon TV apps(Launcher).
3.Final U4 Channel Edit
U4_ChannelEdit: http://smartstb.net/Quad/Firmware/U4Qua ... elEdit.exe
7z program : http://smartstb.net/Quad/Firmware/U4Qua ... /7z920.exe
U4 channelEdit Manual : http://smartstb.net/Quad/Firmware/U4Qua ... manual.pdf
Salty
Re: New Firmware 22 July 2016
Post by Salty » Sat Jul 23, 2016 4:47 am
Thank you Vivant and to the writers
eurosat
Post by eurosat » Tue Jul 26, 2016 7:22 pm
Helo friends, I am Eurosat country Brazil .. Regards to all lovers of Satellite ..
The latter Software greatly improved the receiver, but I think the channel Editor should estra within the U4, as in any RECEIVER ..
U4 bad Blind Scan Ku, Bad Edit Channel...
Anyone know if you can pick up channels with SR below 1000? Band C
U4 Very good, very good Android Applications ...
U4 Opens 2 Channels tests 4k FTA in Satéilte 61W and 70W ... (Hevc)
See pictures ..
CubaLibre
Post by CubaLibre » Tue Jul 26, 2016 8:15 pm
@xmbc: are you sure this firmware is compatible with your editor 2.01 ?
I did a clean install, fresh db (no channels), full scan on one sat (Astra19.2, Europe)... export DB to USB.. and loaded in Editor.
In ChannelEditor 2.01 all "looks" good, but regardeless what you do and save - DB is "corrupted" afterwards.
It even doesn't matter if you load it back to U4 or re-open in ChannelEditor 2.01 - channels are re-numbered, Fav are different from what you saved...
do a simple test... open DB, do a small change (e.g. move a channel to FAV or delete a channel), save in editor, open it... *bang* :o
jnc
Post by jnc » Tue Jul 26, 2016 9:11 pm
eurosat wrote: U4 Opens 2 Channels tests 4k FTA in Satéilte 61W and 70W ... (Hevc)
See pictures ..
@eurosat : U4 quad is 4K x 2K@30 fps video encoding .
it show imposible 4k / 50p .
you picture "tests 4k FTA in Satéilte 61W" can "Hispasat's 4K tests in 1080i HD" or 4k / 25p .
Hi3796M V100 Brief Data Sheet :4K x 2K@30 fps decoding
http://marketing.glorystar.tv/temp/Hi3796MV100.pdf
eurosat
Post by eurosat » Thu Jul 28, 2016 4:46 am
Excuse my excitement, I did not know 4K at 60 fps ... I think that in Brazil will deceive people with 4k channels 30 fps .... Thank you friends ..so learn more ..
timigo
Post by timigo » Fri Jul 29, 2016 12:30 am
eurosat wrote:Excuse my excitement, I did not know 4K at 60 fps ... I think that in Brazil will deceive people with 4k channels 30 fps .... Thank you friends ..so learn more ..
Amigo Eurosat, o seu box possui o tuner DVB-C? Eu tenho um com o DVB-C, mas ja tentei de todas as maneiras fazer ele encontrar os canais a cabo e não consegui, apenas consegui achar os canais de satélite. Caso o seu seja tenha a cabo tambem, você poderia ver se consegue achar os canais a cabo.
Eu estou desconfiado que ou o meu tuner veio com defeito ou o programa tem um BUG e não acha os Canais no SymbolRate 5217. Se tivesse esse feedback de mais alguem do brasil seria otimo.
Att.
Timigo
eurosat
Post by eurosat » Sat Jul 30, 2016 7:50 pm
Att.
Timigo
Eu não tenho como testar parte de cabo... deixe msn na parte de bugs em INGLES...
Add as Tps manualmente, pois este deco não acha em busca cega ..
I have no way of testing cable ... let msn on the bugs in ENGLISH ...
eurosat
Post by eurosat » Sat Jul 30, 2016 7:54 pm
Thanks @eurostat. We have learned that in some western satellites 4k/25p test broadcast.
I think it would be for all future 4k60p TV channels .but from the studio, up to the street broadcasts and films, it will require many changes.I do not think the transition 4k has been completed in 10 years.
we will watch very long time with1080 HD and 720 SD broadcasts .
DVB 4k , will remain nostalgia and test. maybe 10 years dream. :)
Friend kruegerfreddy in Brazil few channels are TOTALLY HDS .. much still in SD .. broadcast on Hds channels .. channels 100% HD, I think that only in 10 years .. In Brazil and South America.
4K channels, in 20 years, I think .... kkkkkkkkkk
jon_is
Post by jon_is » Tue Aug 09, 2016 7:32 pm
Why cant I turn off LCN?
I dont want channel LCN Numbers
Return to “Firmware”
