New Firmware 20161103
U4 Quad Hybrid
03 Nov 2016, 08:45
New firmware released
*Version keeping user setting:
https://drive.google.com/open?id=0B-Fkg ... W5Rc2tEWlk
*Version fresh install:
https://drive.google.com/open?id=0B-Fkg ... FpRWDluRTA
Change log:
-Updated TP list for Portugal cable
-softcam.key loaded by USB fully working
-General stability improvement
warpspeed
11 Nov 2016, 19:11
Good to see you are still there!
BIOS
14 Nov 2016, 08:48
"keeping user setting" mean keep tuned programms? or also keep other settings like KODI etc?
24 Nov 2016, 10:09
BIOS wrote:"keeping user setting" mean keep tuned programms? or also keep other settings like KODI etc?
Channels will be kept but not Kodi add-ons. Please use Kodi backup to backup and load again after update.
timigo
27 Nov 2016, 19:42
The DVB-C tuner on SymbolRate 5217 still does not work. :(
01 Dec 2016, 05:51
Please provide more information about this symbol rate. Did you try manual search, what is the setting and result?
lovesat2
12 Dec 2016, 04:23
vivant wrote:Please provide more information about this symbol rate. Did you try manual search, what is the setting and result?
The machine has already been produced for nearly a year, the blind scan problem, program Sort problem, the basic function can not be repaired. The engineer is useless.We are very disappointed.
jnc
19 Dec 2016, 07:33
vivant wrote:New firmware released
Change log:
For two years, dozens of firmware.
You can not even solve sorting problem the satellite name and channel name.
Satellite receivers sold at 20usd are much more stable. There is no such problem.
I do not count other problems :D
I do not know , you're writing for which face and what :?
timigo
29 Dec 2016, 10:44
hi Vivant,
Sorry for the delay, I've been busy.
I can not find any channels on the SR5217 because it does not lock on this SR.
When I try to manually add Frequency in the program it always adds the SR6952 and does not give option to choose manually the SymbolRate that I want.
Even adding manually in TVDATA.TAR.GZ file it still does not find any channels because the program can not scan in this SR.
BUG software.
barry21123
01 Jan 2017, 13:14
Hi, downloading from links, there just coming through as white files not compressed files ?
error on u4 quad " file not found " how do you install this new update ? the other updates were straight forward
