issues on the new firmware report!!!
Bugs, Issue report.
13 Nov 2017, 12:58
Hello guys, the u5 team want to know all the issues that your suffering on your u5 Deluxe on the last update, only like this they are able to solve the problems for the final release of atv 7.0.
Please don't ignore
Best regards
13 Nov 2017, 16:27
I think sometimes you have to be part of the solution; so for me the reason why I bought this box was for the OSCAM and is broken as I spoke already with @Vivant, the OSCAM just needs to be patched
so what solution I can think it’ll make easier al this process:
- Build OSCAM as an APK. a lot easier to handle and to maintain just like OSmegatool.apk or OScam Manager from Wetek.
- OSCAM config folder should be under or in SDCARD
- And OSCAM Bin file should also needs to be accessible with any FTP software because as of today I have not been able to find a FTP software that can browse the root directory of the box.
- Also provide a clear how-to compile guide for this box since this is an Android/Debian it is not that easy for me and the instruction from the github are not enough.
scorpion61
13 Nov 2017, 16:59
Hello,
I agree with Danny, the real problem in this box is oscam.
All apps work fine, image qality is great.
But all of this is useless without a working oscam.
13 Nov 2017, 18:16
couldn't agree more, and some users reported broken DRM, that's an issue that needs to be fixed for proper Netflix use, and if possible upgrade the tvheandend also, i now it's complicated because of the eon TV but would be great
14 Nov 2017, 00:11
This is part of what I'm talking about...
there is OSCAM Manager installed on mu u5pvr deluxe ATV7, as of now doesn't work at all, it starts, but doesn't work
14 Nov 2017, 06:44
DannyPTY wrote:
14 Nov 2017, 00:11
wait a minute DannyPTY, don't know if you know but the u5 has already an oscam built-in you don't need to install one yourself, to access the oscam you just need to input Ip of u5:8888
14 Nov 2017, 11:18
Adricool wrote:
14 Nov 2017, 06:44
DannyPTY wrote:
14 Nov 2017, 00:11
In LIVE TV App, Please press "Menu" and press "2580" then you can see "Explorer" ==> Cam Monitor, Load cccam.cfg from USB, Load Softcam.key from USB" , Use Cam Monitor to stop and restart service.
14 Nov 2017, 11:58
Don't get me wrong here both of you guys, what I'm trying to point out is that Vivant needs to focus in an easy solution for them as small company with limited resources for developing software and let the community help them? just like I said in my first post here in this thread
14 Nov 2017, 12:31
DannyPTY wrote:
14 Nov 2017, 11:58
yes having a compatible oscam apk would be easier to upgrade...
14 Nov 2017, 12:40
Image this is in ATV5 is so also in ATV7?
