Enigma2 is coming for U5 PVR.
U5 PVR Deluxe/Slim/Nomral
Re: Enigma2 is coming for U5 PVR.
Post by vivant » Mon Jun 26, 2017 4:11 pm
Neomaster wrote:
Fri Jun 23, 2017 2:50 am
We installed VNC server and working X-window by VNC client.
Enigma2 will come on after figure out some issues what we faced. Maybe after 2 month, it will come with U5 PVR. E2 is working on Lab internally. but will not release until ready with security solution for our U5 PVR HW.
Sounds bad and violation against the GPL of Enigma2.
I hope you can get it run but you can forget the necessary support of the enigma2 community. I am gone to next potential as this seems a one way road.
Once image is ready, codes will be published step by step.
Ramtech
Post by Ramtech » Sat Jul 01, 2017 12:16 am
vivant wrote:
Mon Jun 26, 2017 4:09 pm
Neomaster wrote:
Thu Jun 22, 2017 1:20 am
This is challenging to run E2 as an APP. But we made Linux on Android and maybe E2 on Android is an feasible. We will work on that direction.
Android is based on Linux so that's easy to make linux on Android ;)
The question I think is if you can run under Android a "desktop linux distribution".
Now it seems it can only run "linux" programms which doesn't need graphical engine. I didn't see any distro which runs under Android. ( like ubuntu/fedora and more. )
Enigma2 should get a major upgrade first to follow the android specs. It's almost easier to build something complete new.
As the enigma2 image on U5PVR is still not available after the first announce I assume it's not yet working.
Hope some stuff will come available and follow linux openembedded system so that we can work on it and see the possibilities of this project.
The Enigma2 image is in the final stage of polishing. It will take about 2 months to be at a sellable state. Not wanting to rush into a buggy release.
The graphic engine is the real challenge to have E2 running as an App in Android. We will have a look and maybe it will work.
Hope this works would be great to have it running in a app that can be booted of the leanback launcher
Neomaster
Post by Neomaster » Fri Sep 22, 2017 6:50 pm
Is this project stop?
When sources are available then the community can work on it and maybe then it will have in the end a good working enigma2 solution.
Post by catorcio » Fri Sep 22, 2017 8:39 pm
Post by vivant » Wed Sep 27, 2017 10:21 pm
It is still on. But the Android N is dragging us behind, especially the Widevine is making a lot of trouble for Dual boot.
Post by DannyPTY » Thu Sep 28, 2017 12:53 am
don't let them distract from your goal, keep the great job you all are doing, also with this inovation and ground breaking possibility
Thanks.
Post by vivant » Fri Sep 29, 2017 4:31 pm
Thanks for your support. We will make it.
jirka
Post by jirka » Sun Oct 01, 2017 12:21 am
Post by catorcio » Sun Oct 01, 2017 2:55 am
Is he here?
Post by DannyPTY » Mon Oct 02, 2017 12:32 pm
please make it possible, even more to have the possiblity of a better IPTV option and don't forget about xcas on OSCAM because we need it for powerVU please.
Return to “News & Introduction”
