U5 PVR Firmware-20170420
Post by xbmc » Fri Apr 21, 2017 10:07 pm
Dear customer.
After getting your U5 box, if you want to use full features of U5 PVR, We are recommend to upgrade firmware.
Please kindly download from below links.
We have 3 parts of firmware format.
1. Full version Firmware
- After getting your Box, we strongly recommend to upgrade Full version.
- It will clean all user data and user App. so please download this SW after getting new box or when you need to clear all your data and App.
- If you use this version, also Linux OS will clear. it will load only Android OS part.
2. Normal version Firmware :
- It will update firmware except user data and user Apps.
- To keep your Apps, channel DB and Linux part OS, please use this version.
3. Linux part Firmware :
- Linux partition firmware will locate under Android OS partition.
- Even if you install Linux part Firmware, Android OS part will keep to exist.
1. Full version : https://drive.google.com/open?id=0B9uvs ... Dl4R0Rnd3c
2. Normal version : https://drive.google.com/open?id=0B9uvs ... FVFNEdJc3c
3. Linux version : https://drive.google.com/open?id=0B9uvs ... Upra2RJRGs
I hope that you can enjoy with U5 models.
Return to “Firmware”
