U5 PVR Firmware-20170424
Post by xbmc » Mon Apr 24, 2017 7:39 pm
Dear customer.
After getting your U5 box, if you want to use full features of U5 PVR, We are recommend to upgrade firmware.
Please kindly download from below links.
We have 3 parts of firmware format.
1. Full version Firmware
- After getting your Box, we strongly recommend to upgrade Full version.
- It will clean all user data and user App. so please download this SW after getting new box or when you need to clear all your data and App.
- If you use this version, also Linux OS will clear. it will load only Android OS part.
1. Full Version : https://drive.google.com/open?id=0B9uvs ... k0zRVhjVkk
2. Normal version Firmware :
- It will update firmware except user data and user Apps.
- To keep your Apps, channel DB and Linux part OS, please use this version.
2. Normal Version : https://drive.google.com/open?id=0B9uvs ... S1lSmI2aEk
3. Linux part Firmware :
- Linux partition firmware will locate under Android OS partition.
- Even if you install Linux part Firmware, Android OS part will keep to exist.
3. Linux version : https://drive.google.com/open?id=0B9uvs ... Upra2RJRGs
After releasing SW on 20th April, we found small but critical issue so urgently we fixed below issue.
1. Fixed Malfunction[Enter key, Print Screen key] on keyboard.
I hope that you can enjoy with U5 models.
Return to “Firmware”
