Openatv release
01 Dec 2017, 09:52
Openatv took in charge the development of e2 for the u5, finally a light at the end of the tunnel...
Soon they will release the first firmware for the u5.
Michu7
01 Dec 2017, 10:04
Where is this news come from? u5team or openatv team?
01 Dec 2017, 10:17
Michu7 wrote:
01 Dec 2017, 10:04
From both sides....
01 Dec 2017, 11:44
Finally i can share with you the first firmware release of e2 aka openatv, if you choose to install this firmware you will loose android DRM permanently there's no way back, in my opinion is not worth it, soon they will have a version to boot from sdcard, it's more like a proof that they are working on it ....
http://images.mynonpublic.com/openatv/n ... inobot4kse
01 Dec 2017, 12:30
Adricool wrote:
01 Dec 2017, 11:44
How about oscam?? and softcams??
I wont move forward if this aren't adressed...
01 Dec 2017, 12:34
the boot from sd card works with both ATV5 and ATV7? thank you.
Michu7
01 Dec 2017, 13:15
Adricool wrote:
01 Dec 2017, 11:44
You have posted link to Dinobot4kSE box. Is it good one?
01 Dec 2017, 13:21
Michu7 wrote:
01 Dec 2017, 13:15
Adricool wrote:
01 Dec 2017, 11:44
looks like the dinobot 4kSE is the same like our u5pvr
01 Dec 2017, 13:55
Exactly the same box, only the name change, i mentioned that when they changed their brand name, u5 is not dying only diferente name and more focused on foreign Markets
Michu7
01 Dec 2017, 16:16
So... we wait for magic trick with dual boot. I don't want loose my DRM. I like Netflix app. I think it's only one working ok. Few times freezed but that I can forgive.
