Openatv release
05 Dec 2017, 08:09
Adricool wrote:
05 Dec 2017, 07:29
catorcio wrote:
04 Dec 2017, 22:01
Adricool wrote:
04 Dec 2017, 21:12
No it will not work
upgrade to 7.0 is easy or complicated? I would not like to make it a brick !.
its really simple, just follow the tutorial, anyway if you have difficulty just contact me on facebook
Thanks, I'll do it for sure, the tutorial is just written? It would be better with some images, having to translate with google I would not understand badly. "All existing data (including MAC address information) will be erased." this is what worries me!
05 Dec 2017, 13:21
catorcio wrote:
05 Dec 2017, 08:09
Adricool wrote:
05 Dec 2017, 07:29
catorcio wrote:
04 Dec 2017, 22:01
Tonight i will post the tutorial and it has image
05 Dec 2017, 18:17
Has promise
http://u5pvr.blogspot.pt/2017/09/beta-f ... ember.html
By the way the firmware update for the dual boot is scheduled for friday is everything goes as planned
birali
05 Dec 2017, 20:57
Part1: Update U5PVR ATV7 to dual Boot
https://www.opena.tv/dinobot-4k-se/3814 ... post332582
05 Dec 2017, 21:37
birali wrote:
05 Dec 2017, 20:57
They told Friday, let's see if they manage to release earlier
05 Dec 2017, 23:08
to upgrade to dual boot do I have to put the old beta 7? or directly the new one?
06 Dec 2017, 08:29
How can I change the Mac address after updating the U5PVR firmware? p.s. as not written I got confused with Slim box
birali
06 Dec 2017, 09:02
06 Dec 2017, 12:54
Finally !!
Here I send First U5PVR version firmware with E2.
Full version : https://drive.google.com/open?id=1OhEM7 ... PBSqFr5xkF
Normal version : https://drive.google.com/open?id=1WwEbz ... Yyk6_aL7t0
To use E2 dual boot, please try to update 2 times.
   ==> To make new partition, you need to upgrade 2 times.
Basically, this version had 2 mode
1. Android Only Boot mode.
2. Android/E2 Dual boot mode.
To use Enigma2 mode, please follow this way..
After upgrading this SW, then go below and enable E2
Live TV ==> Setup ==> Misc ==> Preference ==> Use E2 ==> Enable
Then you will have dual boot mode.
06 Dec 2017, 13:15
Adricool wrote:
06 Dec 2017, 12:54
Finally !!
The part that confuse me more is, how do I put E2 in my sdcard…
Could you explain?
Thanks.
