U5PVR Android FW - 2017.12.27-(HDCB Beta Test)
birali
Post by birali » Thu Dec 28, 2017 8:45 pm
https://drive.google.com/drive/u/0/fold ... 0ZIhfZHc9V
Michu7
Re: U5PVR Android FW - 2017.12.27-(HDCB Beta Test)
Post by Michu7 » Fri Dec 29, 2017 2:28 am
What is it in? What is this HDCB about?
Post by DannyPTY » Fri Dec 29, 2017 9:36 am
I just installed it I still don't see any difference so far...
Post by catorcio » Fri Dec 29, 2017 7:07 pm
I have not yet figured out if it's better to stay with Android 5 or upgrade to 7 and put the dualboot, can you advise me?
Post by catorcio » Fri Dec 29, 2017 7:23 pm
can you tell me if with android 7 you see the hdd connected to the usb 3.0 port indicated by the arrow?Image
johnny64
Post by johnny64 » Sun Jan 07, 2018 3:29 am
If I could go back to Atv5, this often blocked me by using the remote!
Return to “Firmware”
