U5PVR Android FW - 2017.12.29
birali
29 Dec 2017, 15:42
-Online upgrade..
-Oscam works perfectly!
-E2 is not working !!!!!
29 Dec 2017, 16:47
birali wrote:
29 Dec 2017, 15:42
-Online upgrade..
Another update?? in less than a week or is it the same ones???
Thanks.
29 Dec 2017, 19:16
Is DualBoot?
johnny64
29 Dec 2017, 20:09
-Online upgrade..
-E2 is working !!!!!
-Is DualBoot!!!!!! :)
-green ok
-wall poster
29 Dec 2017, 20:45
johnny64 wrote:
29 Dec 2017, 20:09
-Online upgrade..
-green ok
-wall poster
which version of OSCAM is this new update having?? is it 11392 OSCAM EMU??? or is the same crappy old one??
I know it does work if you have a paid subscription or IKS server, but for other thing the oscam for SKY that this box has, does not work, the MyXcas Emu needs to be replaced or updated or patched, but how?? if @vivant does not tell us how to do it, or where to find the source code for MyXcas emu for example...
birali
29 Dec 2017, 20:55
johnny64 wrote:
29 Dec 2017, 20:09
-Online upgrade..
-green ok
-wall poster
Hi
http://images.mynonpublic.com/openatv/6 ... 29_mmc.zip
http://pur-e2.club/OU/images/6.1/dinobo ... 29_mmc.zip
I could not run these images...
Regards
29 Dec 2017, 21:05
birali wrote:
29 Dec 2017, 20:55
johnny64 wrote:
29 Dec 2017, 20:09
-Online upgrade..
-green ok
-wall poster
Hi
Regards
make sure you have E2 enable on live tv app...
birali
29 Dec 2017, 21:28
E2 enable...
is there anything else I should do...
startup e2 ....not working
johnny64
29 Dec 2017, 22:06
Get sw on SD and put it in slot sd, power ON, boot, menu, updt, blue ...! ... !!!
29 Dec 2017, 23:13
johnny64 wrote:
29 Dec 2017, 20:09
-Online upgrade..
-green ok
-wall poster
the sat and digital terrestrial TV app works well?
