U5PVR Android FW - 2017.12.29
birali
Re: U5PVR Android FW - 2017.12.29
Post by birali » Sun Dec 31, 2017 7:41 am
catorcio wrote:
Sun Dec 31, 2017 7:21 am
if I have not misunderstood, I have the model U5 PVR Deluxe with Android 5.1 installed to switch to Android 7 should I do as I indicated?
It is true...
You will then upgrade your last update with online update..
Good luck with
Post by catorcio » Sun Dec 31, 2017 8:46 pm
thanks, did you go from Android 5.1 to 7? What are the improvements to you? or vice versa, I wait for the end of the Italian championship before installing Android 7 I'm afraid the oscam will not work well.
Post by xbmc » Wed Jan 03, 2018 7:06 pm
Hello
Based on the software released on the 27th for Korean customer , the final version is released through the online upgrade function.
As a result of our internal verification, We improved Netflix error issue (tvq-pm100) and TV compatibility
The following software has been revised.
Fixed problems.
1. When Netflix is ​​used, sometimes an error code(tvq-pm100) that does not recognize HDCP on TV.
2. No Video issue on some TVs.
Added functionality.
1. An additional app with poster functionality,
2. Added shortcut function for Live TV app .
3. Added OTA notification function which can be notified to box when there is a new version.
U5PVR Deluxe
Full Version: https://drive.google.com/open?id=1kg3tO ... 4KYJJ_A7bt
Normal Version: https://drive.google.com/open?id=1dOFzY ... cbDtSaih8z
Moving Version from ATV5.1 to 7: https://drive.google.com/open?id=14tTMt ... MimLjEuVUl
After releasing this software, the U5PVR software will be released on a monthly basis unless there is an urgent matter.
We release mostly 2 weeks to Korean forum but not in this forum. We focused to clear buts list from Korea customer and testers.
We've made improvements to the users over the course of a year with a lot of software releases
But In 2018, we are expecting that we focus for various overseas users's issues.
U5 team.
Post by DannyPTY » Thu Jan 04, 2018 12:59 am
Hello
Fixed problems.
U5PVR Deluxe
U5 team.
I know I have been bothering a lot with this, but that was the main and real reason I bought this box... for the ability to use OSCAM-EMU(MyXcas), I know now that with E2 it is possible, yes it is possible for me that I'm a tech guy, but not for the wife who likes to use and see her soap drama with CBS all access and then go back to live TV and see other stuff coded with powerVU... but it is not possible now because in order to do this, she needs to reboot the box, press volume down(-) until the box goes to E2 and the tune in her channel, sound simple, but not for my wife, so What I want from Vivant is for god sake, release a proper source code for OSCAM, an OSCAM that can be updated frequently for the community, real ease the code for MyXcas so we can do your job…
Please!!!
Michu7
Post by Michu7 » Thu Jan 04, 2018 8:20 pm
After upgrade OTA with Full option I still have freeze without a cause. Strange.
After upgrade first turn on box and when I chose LiveTV it was launched but took 10 sec and freeze... only Reset button in rear side helped.
Next run was ok.
This kind of behavior makes me worries. I hate it! :|
Post by xbmc » Fri Jan 05, 2018 6:52 pm
Next run was ok.
Dear . Don't worry about this.
After first upgrading Android SW, over 10 ~ 15 seconds, Android OS want to install system files and optimize box.
We know this problem. but it is OS issue and CPU performance issue after upgrading full version.
It will be stable after a minutes..
hope that you understand this issue.
Post by xbmc » Wed Jan 10, 2018 3:31 pm
Hello
Fixed problems.
U5PVR Deluxe
U5 team.
Please!!!
Dear DandyPTY.
Can you help us to upload new PowerVu stream?
We've tested with your old stream(4080-27690-V--580-20170530-183709.ts ). but it is too old. and too short to debug PowerVu AU.
If you can upload stream over 1GB ~ 2GB new stream, we can check your PowerVu AU.
But that channels should be worked with other OSCAM via Enigma2 Boxes.
We can't make PoweVu AU if other box can't.
Wait your feedback.
Post by DannyPTY » Thu Jan 11, 2018 1:58 am
Hello
Fixed problems.
U5PVR Deluxe
U5 team.
Please!!!
Dear DandyPTY.
Wait your feedback.
try with this one: https://mega.nz/#!RdEw1CgT!jTdvOKQ2mKn7 ... LLV5cZNSK4
almost 2gb of data and I know I get it with my Gigablue with my PC and more, but sometimes I'm not at home and the wife needs her TV show and stuff up and running and if this is enable it'll be a huge win for me...
Return to “Firmware”
