DVBC drivers
scorpion61
05 Jan 2018, 08:08
Hello,
When I use Openatv on my U5PVR, the DVBC channels are perfect, without problems.
When I use live tv app on ondroid, or tvheadend, I have a lot of glitches and freezes.
I think this is a problem of drivers for android.
Do you plane to update those drivers ?
best regards
Scorpion
05 Jan 2018, 09:48
scorpion61 wrote:
05 Jan 2018, 08:08
Hello,
best regards
Scorpion
do you using OSCAM to decrypt channel? , Is that FTA channel or Scramble channel?
If it is FTA channel. Can you upload after capturing stream from U5PVR box?
scorpion61
05 Jan 2018, 19:34
The problem is on fta and scramble channels.
It's not an oscam problem.
With direct tv, the signal is 56%
With enigma2 openatv, it is 88%.
It's really a driver problem.
The tuner is less sensitive on android.
