Some questions on U5PVR before buying
Re: Some questions on U5PVR before buying
Post by catorcio » Mon Jul 10, 2017 6:28 pm
Arrived this morning, I did the first steps 1) WiFi 2) Language selection 3) update was already updated, more search digital terrestrial channels, I regret having bought it! (After spending €108 for the KIII) prime Imprezioni very positive, very good quality materials, even the video quality seems to me much better than the KIII, I have not yet figured out how to see the MKV from USB.
Post by Adricool » Tue Jul 11, 2017 3:00 am
Catorcio contact me on Skype (adrianocrew) or Facebook (Adriano Mateus) to talk easier
Post by catorcio » Tue Jul 11, 2017 6:20 am
I tried on Facebook (Adriano Mateus) but I have not seen you anyway (almost) all good channels ok ok but the engine is moving bad, now i need to inform me how to insert the c-line, i tried the tvsat card all perfect, change channels Very fast clock, thank you for the advice
Post by Adricool » Tue Jul 11, 2017 7:12 am
OK, so for cccam you Need to go to your browser (Chrome) input your box IP:8888, and then go to files, oscam.server and input your cccam information, restar oscam and your good to go
Post by catorcio » Tue Jul 11, 2017 5:19 pm
You mean from PC or directly from U5PVR ? If from the Firefox pc okay?
Post by Adricool » Tue Jul 11, 2017 8:43 pm
From PC, Firefox is fine
Post by catorcio » Tue Jul 11, 2017 9:05 pm
I tried but did not connect, I'm gonna get something wrong.
Post by Adricool » Tue Jul 11, 2017 11:55 pm
You need to input ip:8888 example (192.168.1.103:8888)
Post by catorcio » Wed Jul 12, 2017 3:21 am
Adricool wrote:
Wed Jun 07, 2017 4:01 am
catorcio wrote:
Tue Jun 06, 2017 6:38 pm
If I can ask if Stab motorized parabels are handled well by the U5PVR? Multistream channels are tunable?, Oscam also works on digital terrestrial channels? thank you.
yes multistream works fine as long you are on the same satellite for both channels.
Today i tried to do a scan on 5w but the multistream channels did not tune them, how did you do it? thank you
Post by Adricool » Wed Jul 12, 2017 3:31 am
First tell me how you did Try it, maybe the multistream your are talking about is another thing that i was thinking, when I'm talking about multistream is to manage to stream the same channel to diferent box/TV/pc/cellphone
