Can U5 be used as Server: oscam/Cccam/ MgcamD
Robbin2685
Post by Robbin2685 » Sat Jun 10, 2017 5:22 am
Hi Everyone,
I wanted to know if U5 be used as Cccam or other server boxes to share the subscription with other receivers if I use a valid Conax or irdeto or a videoguard card?
Does the box recognise the videoguard CA Card?
Thanks,
Tarun
Re: Can U5 be used as Server: oscam/Cccam/ MgcamD
Post by xbmc » Tue Jun 13, 2017 2:59 pm
Hi Everyone,
Thanks,
Tarun
Do you mean that you want to use U5 box as card server?
if yes, then you can use that way but we didn't test exactly videoguard card.
Robbin2685
Post by Robbin2685 » Thu Jul 20, 2017 6:28 pm
Thanks. I wanted to share any of my valid subscriptions, I've cards which are paired with receivers as available in India like Irdeto, conax, videoguard but all these cards are paired with their receivers, still searching how to take out key from these receivers. ;)
And yes, once I've this setup on U5 as server (wherein I'm using U5 as alternate to dreambox) for hosting my card sharing server.
Post by xbmc » Thu Jul 20, 2017 6:35 pm
yes, you can.
also, you can download code and make own your OSCAM.
https://github.com/dizzdizzy/HiOSCAM/tree/master
Robbin2685
Post by Robbin2685 » Thu Jul 20, 2017 11:33 pm
Thanks a lot for responding so quickly but I'm able to browse the link, it's showing error 404 page as mentioned in attachment.
Kindly share the correct link.
birali
Post by birali » Fri Jul 21, 2017 4:19 am
Presentation of Eddy Lab.....
"His OSCAM
How to compile OSCAM for U5/U4 Quad
download github files and modify oscam.source
Use Ubuntu 14.04 to compile
U5 model : ./make-u5.sh
After compiling it, related OSCAM files will be located "u5.release" folder for U5 or "u5.release" for U4 Quad.
copy all files in u5.release or u4.release folder to /system/oscam folder in box.
reboot box then you can use own your OSCAM."
Robbin2685
Post by Robbin2685 » Sun Jul 23, 2017 10:34 pm
"His OSCAM
Thanks a lot for helpful links and hard work to assist me.
I know that all the providers here in India bind box with cards. When I read, a learnt about RSA key in the box. I tried to locate JTAG pins but no success. Can you also help me by providing some link to know more about RSA key extraction process.
Thank you so much for your wonderful support till here.
Post by vivant » Mon Jul 24, 2017 3:04 pm
Please do not post about RSA key stuff in the forum. It is prohibited to talk about that with us as it is not our business.
joker@
Post by joker@ » Thu Sep 28, 2017 9:43 pm
"His OSCAM
Hi
Be honest... maybe Im too old and too dumb but from above can catch what i should do to compile oscam.
If someone did this already could share this info step by step pls.
Tried couple time but looks like Im doing something wrong.
Need compile it with complete support for my card which is nagra and this oscam in our box is without this support.
root@:/home/Desktop/os/oscam-svn# ./make-u5.sh
/home/Desktop/os/oscam-svn/android9-gcc4.8-toolchain/bin:/home/Desktop/os/oscam-svn/arm-histbv310-linux/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:
gcc (Ubuntu 4.8.4-2ubuntu1~14.04.3) 4.8.4
Copyright (C) 2013 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
RM build/-his
RM tests
make --no-print-directory \
LIB_RT= \
LIB_PTHREAD= \
CROSS=arm-linux-androideabi- \
USE_HISKY=1 \
--jobserver-fds=3,4 -j -- HISKY_FLAGS=-D__ARMEL__\ -I/home/Desktop/os/oscam-svn/u5sdk/include\ -DWITH_HISILICON=1\ -DSDKV600\ -DSDKV660\ -DSDK3798C HISKY_LIB=-L/home/Desktop/os/oscam-svn/u5sdk/lib\ -lhi_msp\ -lhi_common
| OSCam ver: 1.20.sky rev: 0 target: -his
| Tools:
| CROSS = arm-linux-androideabi-
| CC = arm-linux-androideabi-gcc
| Settings:
| CONF_DIR = /data/oscam
| CC_OPTS = -fPIE
| CC_WARN = -W -Wall -Wshadow -Wredundant-decls -Wstrict-prototypes -Wold-style-definition -Wno-unused-function -Wno-unused-parameter
| CFLAGS = -D__ARMEL__ -I/home/Desktop/os/oscam-svn/u5sdk/include -DWITH_HISILICON=1 -DSDKV600 -DSDKV660 -DSDK3798C
| LDFLAGS = -fPIE -pie -D__ARMEL__ -I/home/rav/Desktop/os/oscam-svn/u5sdk/include -DWITH_HISILICON=1 -DSDKV600 -DSDKV660 -DSDK3798C
| LIBS = -L/home/Desktop/os/oscam-svn/u5sdk/lib -lhi_msp -lhi_common -ldl
| UseFlags = USE_HISKY=1
| Config:
| Addons : WEBIF WEBIF_LIVELOG WEBIF_JQUERY TOUCH HAVE_DVBAPI IRDETO_GUESSING CS_ANTICASC WITH_DEBUG MODULE_MONITOR WITH_LB CS_CACHEEX CW_CYCLE_CHECK
| Protocols: XCAS CAMD33 CAMD35 CAMD35_TCP NEWCAMD CCCAM CCCSHARE GBOX RADEGAST SCAM SERIAL CONSTCW PANDORA GHTTP
| Readers : NAGRA IRDETO CONAX CRYPTOWORKS SECA VIACCESS VIDEOGUARD DRE TONGFANG BULCRYPT GRIFFIN DGCRYPT
| CardRdrs : INTERNAL
| Compiler :
| Config : build/-his/config.mak
| Binary : Distribution/oscam-1.20.sky.0
GEN webif/pages.c
GEN Compressed 385720 template bytes into 160827 bytes. 224893 saved bytes (58.30%).
make[2]: arm-linux-androideabi-gcc: Command not found
make[2]: *** [build/-his/cscrypt/aes.o] Error 127
make[1]: *** [all] Error 2
make: *** [android-arm-hisky] Error 2
SVN_REVISION:0
/home/Desktop/os/oscam-svn/u5.release.........
