Disable Service app does not work on rooted device
mecki
Post by mecki » Wed Jul 19, 2017 3:02 am
I've followed the rooting instructions from the manual section here and it seems to have worked fine. SuperSU works and Root Checker says, that rooting is fine.
Now I tried to use Disable Service e.g. to get rid of the recommendations on the home screen. Unfortunately the app does not work correctly. It starts, but if I select a service it seems to crash. It never asks for root permission.
Does anyone maybe have a solution for this?
