My ccamd
62bug
My ccamd
Post by 62bug » Fri Aug 11, 2017 8:57 pm
When I put ps info in my ccamd and select save and connect then go back to home screen
says scrambled.
So I go back into server and select my ccamd and the info that I entered and saved is not there.
I have done this same procedure on my U4 with no problem.
Any thoughts would be welcome
Thanks.
Re: My ccamd
Post by Adricool » Sat Aug 12, 2017 5:22 pm
better to go to the oscam Web interface and input the data (oscam.server file)
Dells
Re: My ccamd
Post by Dells » Sat Aug 12, 2017 10:55 pm
I believe they are running CCAMD in North America. The original firmware does not have this problem. Is it possible to downgrade firmwares? Maybe that will resolve?
62bug
Re: My ccamd
Post by 62bug » Thu Sep 21, 2017 12:20 am
So last night I installed firmware from april and it took and rebooted
I then went into servers and deleted the info that was already there in the newcamd section.
I then entered my ps info same process I did on my U4 QUAD.
I selected save and connect then exit out to TV.
Says scrambled. I go back into server open newcamd and the old ip add. is there mine is not saved.
There has to be something I am missing.
