LiveTV - USB stick or SDCard not visible
U5_I_want_one
Post by U5_I_want_one » Fri Oct 20, 2017 5:59 pm
Hi,
I can't "see" USB stick or SDCard from LiveTV app.
I want to use it for PVR or for exporting channel list - but I can't....
Also how should I mount a network drive for the PVR to use? Anyone knows?
Re: LiveTV - USB stick or SDCard not visible
Post by catorcio » Fri Oct 20, 2017 9:15 pm
which firmware has installed? I installed the latest one with android 5.1 the key sees it and registers it! ,I forgot !, if you have the internal hdd you have to go to settings and disable it.
