Wrong permissions on snapshot directory
Bugs, Issue report.
mecki
Post by mecki » Fri Jun 30, 2017 6:06 pm
I created some snapshots and found out, that I can not open the snapshots in the file manager. So I connected the USB stick to my Linux PC and found that the directory permissions for the snapshot directory are missing the +x flag:
Code: Select all
drw-rw-rw-  2 root  root  4,0K Jun 30 10:49 snapshot
I've fixed it with
Code: Select all
sudo chmod +x snapshot
Now I can open the snapshots just fine also in the device's file manager. Maybe you want to fix this in your firmware.
Return to “Reports”
