[SOLVED] Can not boot into Live TV
Bugs, Issue report.
mecki
Post by mecki » Fri Jun 30, 2017 7:37 pm
Under Settings -> Home I have selected "Live TV" but still the box always boots into the Home screen. How can I fix this?
Side note: The menu in Settings -> Home is somehow broken. I could move the cursor with up/down but I could not select any option. When I clicked OK nothing happened. I found, that it has to do with selecting the whole line including the trash bin on the right. I had to play around with up/down/left/right buttons until it did only highlight the left part of a line. Then I could click OK and it selected the option.
Re: Can not boot into Live TV
Post by Adricool » Sun Jul 02, 2017 5:58 am
hello mecki, don't expect to have a fix on it, now they are working extensively on developing android 7 for the u5 , leaving to side the bugs on 5.1, i now it's bad for some people, and understand that more people involved on atv 7, faster it will get out for the user to enjoy... Anyway anything that we can help (community) we will.
Post by DannyPTY » Thu Jul 06, 2017 12:42 am
try a factory restore...
mecki
Post by mecki » Mon Jul 10, 2017 6:09 pm
Thanks, I know you try to help. But instead of blindly trying this and that I'd prefer a proper bug fix. That's why I'm reporting this here.
Post by xbmc » Mon Jul 10, 2017 10:34 pm
==> No way to support any other launcher except Leanback launcher. but when you turn off box and on from live TV channels, then box will reboot on TV channel
==> On ATV, there is not way to use other Launcher except Leanback launcher. so it should be blocked on Setting menu.
mecki
Post by mecki » Tue Jul 11, 2017 1:34 am
This does not work for me. I now did a full factory reset. Note, that I don't use "standby" but "Power Safe mode". The system always boots into the home screen, never into LiveTV.
I don't have any "Leanback Launcher" in that menu. The three options are:
  • Home Screen
  • com.android.provision.DefaultActivity
  • LiveTV
After a factory reset, none of these options is selected! But I was able to change this. But no matter, which option I chose, it's no difference: It always boots into the Home screen, never into LiveTV.
Post by Adricool » Tue Jul 11, 2017 2:24 am
  • Home Screen
  • LiveTV
Hello mecki, try this app it load any app that you want at boot, not a permanent fix but... https://play.google.com/store/apps/deta ... .autostart
Post by xbmc » Tue Jul 11, 2017 9:14 am
==> Yes, you are right, when you use Power Save mode, System will boots on home screen.
  • Home Screen
  • LiveTV
==> Yes, you are right. we should check how to boot with default boot. because ATV system is only support Leanback launcher as default.
So we should block or find some way to support your request.
mecki
Post by mecki » Wed Jul 19, 2017 3:10 am
@Adricool I've tried that app but the LiveTV app doesn't show up in the list. Yes, I've already checked "Show all apps". So still no workaround.
mecki
Post by mecki » Mon Dec 18, 2017 5:07 pm
With the 171201 firmware release this issue is solved. I now can boot into Live TV!
Thanks!
Return to “Reports”
