Kodi refresh rate fix / workaround
Bugs, Issue report.
ovidiuss
Post by ovidiuss » Tue Sep 12, 2017 5:57 pm
Dear U5PVR fans im pretty sure many of you using popular Kodi software and you also noticed the stutter and image jitter while you play different frame rate video content.
here is the fix for U5PVR (works only with android 7 firmware)
- download Looun Add-on repository and copy to Q5/Q10 Pro: https://github.com/looun/Kodi-Repositor ... p?raw=true
In KODI:
- System
- addon...
- Install from zip file
- select the repository.looun.ropo-1.0.0.zip file
- after install repo go install program HI Frequency Switcher addon
- go to HI Frequency Switcher addon
- select "Service"
- ENABLE Playbacks Stars
- ENABLE Default 60 hz or 50 hz
- now "Save configuration"
- exit and restart kodi
after restart of kodi refresh rate will switch automatically based on the frame rate of your played video content.
Enjoy
Re: Kodi refresh rate fix / workaround
Post by vivant » Wed Sep 27, 2017 10:19 pm
Nicely done Ovidiuss
Return to “Reports”
