Should I upgrade?
Bugs, Issue report.
U5_I_want_one
Should I upgrade?
Post by U5_I_want_one » Fri Oct 20, 2017 5:55 pm
Hi,
I just bought U5 PVR and it came with firmware dated end of August.
So I upgraded manually (USB stick) to the beta version from 30th of September.
Now, when I go to "System upgrade/backup", and select "Upgrade Online", I can see I've got 3 options:
Full
Normal
Linux
Should I update with Full/Normal? Is there a newer firmware available than the one from 30th of September?
Re: Should I upgrade?
Post by DannyPTY » Wed Nov 08, 2017 12:59 am
do a full update then do linux...
Regards
Post by Adricool » Wed Nov 08, 2017 5:24 am
Yes you can do a full update, linux is optional it depends on what you will do with your u5, and by the way welcome to this yet small community but fantastic people.
Post by catorcio » Thu Nov 09, 2017 1:36 am
Post by Adricool » Thu Nov 09, 2017 6:58 am
Hahaha Catorcio your so funny ! Nice to have you onboard.
Return to “Reports”
