1) apt-get install tightvncserver -y
2) tightvncserver
If you run tightvncserver after the first installation, you can install the password in the password setup process.
X window installation for Linux.
3) apt-get install mate-core mate-desktop-environment-extra* mate-themes -y
: Modify it to match the installation of package 3..
4) nano ~/.vnc/xstartup
#!/bin/sh
xrdb $HOME/.Xresources
xsetroot -solid grey
#x-terminal-emulator -geometry 80x24+10+10 -ls -title "$VNCDESKTOP Desktop" &
#x-window-manager &
# Fix to make GNOME work
export XKL_XMODMAP_DISABLE=1
#/etc/X11/Xsession
/usr/bin/mate-session
Edit it as above.
Fix the default connection port. If you do not do this, the connection port is changed.
5) nano /usr/bin/vncserver
Modify the monitor resolution information below. I set it to the TV resolution for the demo.
#$geometry = "1024x768";
$geometry= "1920x1080";
Modify the port details below.
#$vncPort = 5900 + $displayNumber;
$vncPort = 5900;
6)netstat -tnlp | grep "5900"
Make sure Xtightvncserver is running and working as shown above. If it does not work
7) Run tightvncserver again
Modify script for autorun at boot time.
8) nano /etc/rc.local
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
/etc/init.d/hostname.sh start
tightvncserver #added....
exit 0
tightvncserver #added.this line.
It seems that all preparations have been finished. Boot the box.
You can set the router for external use. 5900 port forwarding to U5PVR ^ ^
Now you can connect from outside.
This is an example of running the TightVNCClient program on a PC. ^ ^
The default port is 5900, so if you put in the address, the authentication window will appear as shown below.
It is the execution screen after connection.
You are connected to U5PVR. ^ ^
The picture below is a picture from U5PVR using VNC client APP
Now play with U5PVR and Linux on Windows ^ ^
apt-get install iceweasel : Installing Firefox.
