How to access via FTP
Post by catorcio » Thu Jul 13, 2017 5:05 am
You can access via FTP to the U5 PVR?
Re: How to access via FTP
Post by xbmc » Thu Jul 13, 2017 9:53 am
If you install Linux system on U5 PVR from our OTA server , yes, you can.
Any FTP program,
Put your U5PVR IP address
Pass : u5pvr
Post by catorcio » Thu Jul 13, 2017 5:23 pm
With android is not possible? I do not know how to install Linux.
Post by xbmc » Thu Jul 13, 2017 5:26 pm
On home Screen, ATV Settings ==> Device ==> About ==> System update ==> Upgrade Online ==> Linux
You can download above place via online updating.
Refer as below link
viewtopic.php?f=73&t=8525
Thanks..
Post by catorcio » Thu Jul 13, 2017 6:43 pm
When I click Upgrade Online Linux does not appear, is it already installed? Here is information
Post by vivant » Thu Jul 13, 2017 7:39 pm
Use any FTP software on computer and login with:
Box IP: example 192.168.x.xxx
Port: 21
user name: u5pvr
Password: u5pvr
Post by catorcio » Thu Jul 13, 2017 8:49 pm
I tried it does not work
Post by xbmc » Fri Jul 14, 2017 7:11 pm
I think you tried to connect with same IP on PC and Box. please check Box IP address and try again.
Post by catorcio » Fri Jul 14, 2017 9:03 pm
No, I have tried again and with the same IP from Firefox connects while with FTP program no.
Post by vivant » Sat Jul 22, 2017 1:07 am
Try FileZilla, maybe the software you are using is not compatible.
Return to “Others”
