How to set U5PVR Bluetooth voice remote control
12 Jul 2017, 03:14
This Remote doesn't have the Air Mouse function;
Image Image
The remote requires two AAA batteries. (Battery not included)
Move ATV Settings ==> Remote & accessoriese ==> Bluetooth .
If your box doesn't turn on Bluetooth function, then please turn BT on. Please remember that BT/WIFI Antenna should be connected.
Enter Setting menu.
If you put AAA battery on BT RCU, then you can see device name(U5 Remote) on Bluetooth Setting menu.
If you do not see the U5 Remote device, press Menu button on RCU then right top, you can see "Refresh" , Press "Refresh", then box will show all BT devices of nearby you.
If you still can't see "U5 Remote" device, try pressing the On / Off key on the top right corner of the Bluetooth main menu to search for the device again.
On the U5PVR Bluetooth remote control, press and hold the gear button (setting) next to the power button at the top of the photo for about 5 seconds to activate Bluetooth pairing.Select "U5 Remote" in Menu and press "OK" button on remote, then BT RCU will be paired.
Check "Connected" on bottom of device name. if you get "Connected" message, It mean that you are ready to use BT RCU with voice search function.
Press "Mic" button on BT RCU anywhere.
If you get above screen, then you are ready to use BT RCU.
U5 Remote connected well.
Now when you press the Bluetooth direction key, the cursor will move. ^^
For BT RCU, we added "Virtual Keypad" on LIve TV APP.
When you press the "123" key on the U5PVR home launcher below, the Live TV app will automatically launch and enter the LIVE TV broadcast watching state.
After press "123" button, you can select virtual key pad by pressing Up/Down buttons.
BT Voice searching function was tested by English/Spanish/Korean/Chinese/Russian.
