New Firmware release : 2014.05.15
15 May 2014, 14:58
# 15.May 2014
- Added FastScan for EU users : Support Manual/Preset Scan/Blind Scan/Fast Scan
- Added Channel Find Feature on the channel list.
- Added Movement Feature.
- Improve operation by WebIF.
- Added MultiScreen Feature.
= Usage
* Network Environment
Before multi-screen networking, ensure that the STB and hand-held device are in the same network.
Network environment affects user experience.
* STB
Ensure that the multi-screen application has been installed on the STB.
In SetupWizard, select Multiscreen server and have to checked "MultiScreenServer"
* Android Mobile Devices
At present, only Android (2.3 or later) devices are supported.
Enable WiFi for the hand-held device and connect to the WIFI.
Recommend to use same WIFI network between STB/Mobile devices.
Install the multi-screen application (HiControl.apk) on your Android Mobile Devices
Tap the HiControl icon to enable the multi-screen application.
If you can see your box, can connect your Android Device and Settop box.
Ref : http://www.xbmc4stb.net/viewtopic.php?f=13&t=28
Unclean Version : Backup Channel DB and install.
Clean Version : Clean Channel DB and Install.
