[Android] How to edit App icons on Leanback Launcher
4K UHD Android ATV box with DVB/ATSC tuners
Post by xbmc » Fri Apr 21, 2017 7:31 pm
How to move App Icon on Leanback Launcher.
1. Move cursor to APP what you want to move
2. Press OK button on RCU over 5 seconds.
3. Move Icon where you want to locate and press OK button on RCU.
4. choose "Done" button to save your selection.
Re: [Android] How to edit App icons on Leanback Launcher
Post by DannyPTY » Thu May 25, 2017 7:48 pm
If I want to replace one of the icon with some of the apps I use regularly?
Salty
Post by Salty » Sun May 28, 2017 11:11 am
Agreed, can we delete some of the default App Icons completely?
And then be able to add our own Favourites to the list.
Post by xbmc » Mon May 29, 2017 7:10 pm
I will leave a little explanation for the problem above.
Apps that are not built for Android TV option, will only exist in My APP after installation.
However, it will convenient if App can run as shortcuts on the HOME screen
So here we explain how to make shortcut on the HOME screen.
1. Install the TV App Repo app from the Google Store.
2. The following screen appears. We are going to create the shortcut on Leanback Launcher
3. Scroll down to select "Leanback Shortcuts".
4. Let's try to make shortcut with "Cappy Chick" app. Please select an app.
5. If it is a game App, specify it as custom. If you are a regular app, select create shortcut immediately.
6. Wait 10 seconds and the installation window will appear. Install it.
7. The app is installed.
8. "Happy Chick" App has been added to the game selection.
Hope that will be helpful to add Icon to Leanback Launcher.
Post by xbmc » Mon May 29, 2017 7:12 pm
Leanback Launcher doesn't have a way to delete App Icons except deleting App.
You can add your APP from My App list like above explanation.
Return to “U5 series”
