U4 Quad Hybrid Firmware History
U4 Quad Hybrid
Salty
25 Mar 2016, 05:16
satman wrote:
i have no rs232 cable and im not electroniker and make so one cable! shit way what you say!
your SDK killed the box, no more way. good bye
Money for nothing!
What a selfish attitude, i feel sorry for Manufactures that have to deal with people like this.
Not only do they struggle to describe their problem in common English, or even in a civil manner.
Makes you wonder if they had this much trouble, did they even update the firmware correctly in the first place?
Glad it is resolved for you satman, but boy, you sure carry on instead of just solving the problem.
We have all had a bricked E2 or Android Box before, its nothing to cry over, just fix it.
Salty
25 Mar 2016, 05:21
dude-nl wrote: Also why every update all Kodi settings are away?
That's no good. Have to install all addons over again :(
What? A software engineer that doesnt understand what a ROM update does?
Tell me another Android box that remembers the Kodi setting when you update the ROM firmware?
Why don't you just back up all your Kodi addons and settings before you upgrade the firmware
Then when upgrade is complete, launch Kodi and reinstall all you addons.
dude-nl
25 Mar 2016, 15:48
Wetekplay...
Only if the Kernel is updated then you need to backup and reinstall.
These updates of the U4 could be done without updating the kernel.
Besides, there was nowhere stated that it was a full rom update. I hoped that was the difference between full update and normal update.
dude-nl
25 Mar 2016, 15:50
Ofcourse I have a backup, but it wouldn't be necessary...
Making backup in Kodi is slow.
It's faster to reinstall it :)
CubaLibre
25 Mar 2016, 16:59
it's not just Kodi, it's also Oscam and other settings that are gone if you do a partial upgrade
thus, Vivant should partition the internal storage:
1) core Android / kernel
2) pre-installed Android applications / APK's
3) eON / Vivant related stuff
4) "user" space / configs
and only "upgrade" 3)
or even better... make "real" eON / TVH APK's that can be installed / uninstalled
satman
25 Mar 2016, 19:22
Money for nothing!
ist fixed read before old Posts!
profesori
21 Apr 2016, 18:12
acceess code cccam please for last version
profesori
28 Jun 2016, 09:29
dear xbmc
i am waiting for an answer
how can access to hide menu 2,8,5,0 on the last version?????????
thx
Digitaldan
29 Jun 2016, 11:21
It is 2580 ...... not 2850..... and it works fine........
profesori
14 Jul 2016, 13:03
Is 4k supported by u4 dvb s2?????? a lot of channels uhd had zapping.
